Brick Hatch Pattern, with Mortar Joint?
14 replies to this topic
#1 Jon Davis
Jon Davis
  • 541 posts
Posted 06 September 2019 - 08:10 AM
When creating 2D elevations, it would be nice to have a brick hatch pattern in paint, that shows a mortar joint...
For a more realistic look. Anyone have a work around for this?
#2 Henry Buckner
Henry Buckner
  • 342 posts
Posted 06 September 2019 - 08:22 AM
You can make your own paint patterns-this one would be fairly easy to do, I think.
#3 Kevin Rabenaldt
Kevin Rabenaldt
  • 391 posts
  • LocationSan Antonio
You would need to create a custom paint for this.  If you are looking for accuracy then you need the actual brick size.  Since there are many brick sizes, you may need to create a number of different paint patterns or you could create one base on your most common brick size used in your area.
#4 Martin Livingston
  • 693 posts
Posted 06 September 2019 - 09:34 AM
You really only need the one pattern. Once you have the pattern you like you can scale it to meet the needs of different brick sizes.
  • Jon Davis likes this
#5 Jon Davis
Jon Davis
  • 541 posts
Posted 06 September 2019 - 01:40 PM
Have any of ya'll created your own pattern?
#6 Kevin Rabenaldt
Kevin Rabenaldt
  • 391 posts
Posted 06 September 2019 - 02:17 PM
Martin, it all depends on what you are after.  If you adjust your pattern, then mortar joint size changes also.  If you are only after the look, then yes adjusting the pattern size works.  I just use the standard pattern that SP supplies and I have never had anyone complaint about it.
#7 Mark Petri
  • 1,507 posts
Posted 06 September 2019 - 04:42 PM
You can take the existing pattern and do a copy, paste and clean up to get offset lines for mortar. Then save as a new pattern. You'll find most paint patterns are very small lines, but you might be able to get the look you want as easily with a fresh start if copying an existing pattern doesn't work. Also, you could stretch (adjust size) the existing single line pattern for each brick size you want including the size of the mortar joint, then duplicate and offset for the width of the mortar. It may help to set up some long guide lines to assist with moving things, and maybe group each set of lines initially.
Posted 06 September 2019 - 05:56 PM
I've created a number of custom patterns, and I find the easiest way is to draw a repeating pattern, and then draw the pattern template over it, rather than try and draw within the pattern template.
#9 Jon Davis
Jon Davis
  • 541 posts
Posted 09 September 2019 - 06:26 AM
I created my own, it was pretty easy... I'm not sure how I like it though. It does look more realistic but it also makes the elevations look
a little, busy.
So I'm kinda on the fence.
#10 Richard Rubinski
  • 604 posts
Posted 09 September 2019 - 07:47 AM
a little, busy.
Jon, I have some custom Brick Pattern's. I don't know which one's came with SoftPlan, some of them I downloaded from the old Splash forum years ago. If you see one that you like I'll be happy to send it to you.
Rick
#11 Dennis Hilborn
Dennis Hilborn
  • 816 posts
  • LocationDFW Texas
Posted 09 September 2019 - 08:07 AM
I guess I'm just set in my old ways but for brick on elevations it just use horizontal lines 3" apart.  drawing mortar lines or even just individual bricks looks much too busy for me.
#12 Jon Davis
Jon Davis
  • 541 posts
Posted 09 September 2019 - 08:23 AM
Rick
That rough brick looks pretty cool.
#13 Tom Rogers
Posted 13 September 2019 - 06:23 AM
Tried to attach the .spy file that i use but it wouldn't accept.  Give me your email and I can send it separately
#14 Jon Davis
Jon Davis
  • 541 posts
Posted 13 September 2019 - 06:37 AM
Richard sent me his. Update on it, after adjusting pen style settings, I've got it all looking pretty good now. Just need to lighten up the rowlock pattern
a little bit.
#15 Richard Rubinski
  • 604 posts
Posted 13 September 2019 - 02:06 PM
a little bit.
Jon, I use a light gray for the paint.
Rick
