The "Add Drywall" to "Hole" in a wood truss floor system with "Sill Plate" does not account for the "Sill Plate" and leaves a gap.
Anyone else?
SP09.jpg 162.82KB 0 downloads
Posted 13 September 2019 - 07:34 AM
Anyone else?
Posted 13 September 2019 - 08:05 AM
Anyone else?
Is there a reason you're using a sill plate on the second story? In my area the second story trusses bear directly on the first floor walls.
Posted 13 September 2019 - 09:09 AM
Sill is on top of first floor wall under second floor system.
First floor is block. Engineer wants it that way.
Posted 13 September 2019 - 10:54 AM
Tom you may be able to edit the plate definition and add sheetrock inside
or create a wall that is a plate with sheetrock inside and outside being whatever
finish material you are using and replace the sill plate with the new wall.
Roof Hole and Soffit ProblemStarted by Wendall Hilty , 23 Feb 2022 Roof, Hole, Soffit, Problem |
SoftPlan version 2020 →
Dormer shaft. Hole in roof / Hole in Ceiling -> Add Drywall not workingStarted by Tom McConnell , 26 Dec 2019 Dormer, Hole in roof and 2 more... |
SoftPlan 2018 →
Cutting a hole in roof leaves unwanted linesStarted by Dennis Hilborn , 13 Mar 2018 roof, hole |
