Character Setup
8 replies to this topic
#1 Brian Berzinskis
Brian Berzinskis
  • 470 posts
  • LocationNew Jersey
Posted 09 October 2019 - 12:17 PM
I was just going through and changing my font sizes for printing a drawing at a different scale. Just out of curiosity, does everyone have size type grayed out to Custom for Dimension Numbers and Opening Sizes or is that only mine. Like it won't allow me to select Small, Medium or Large and just enter a custom number size instead.
#2 Richard Rubinski
  • 604 posts
Posted 09 October 2019 - 12:38 PM
Brian, mine are grayed out also. I can't find anywhere to change that.
Rick
#3 Mark Petri
  • 1,506 posts
Posted 09 October 2019 - 12:52 PM
Is this at the project or drawing level? Could it be that it is tied to the system options or locked in some other way?
#4 Richard Rubinski
  • 604 posts
Posted 09 October 2019 - 01:33 PM
Mark,
It's also locked in the System Options
Rick
#5 Jon Davis
Jon Davis
  • 541 posts
Posted 09 October 2019 - 02:07 PM
You can change it but you have to do it in the settings box not the drop down...
Let me pull it up and screen shot it... .i'll be right back.
#6 Jon Davis
Jon Davis
  • 541 posts
Posted 09 October 2019 - 02:10 PM
Ok so when you put in text sizes for the small medium & large on the left, then you can pick which one you want for each instance on the right.
The dimensions can be set to custom, and you can enter it there to the right.
Hope this helps!!
#7 Richard Rubinski
  • 604 posts
Posted 09 October 2019 - 02:27 PM
Hope this helps!!
Jon, I we know that. We can't figure out why Custom is grayed out on the Dimension's. It doesn't make since why.
Rick
#8 Philip Frank
  • 560 posts
Posted 10 October 2019 - 04:57 AM
Becuase " Custom" isn't a preset size. It requires you to pick a custom size when you select it while placing text.
#9 Don Gibbons
Don Gibbons
  • 375 posts
Posted 10 October 2019 - 06:04 AM
I don't mind the custom on dimension numbers and opening sizes. My dimension numbers are slightly larger than than detail notes and don't line up with S, M, L or XL.
