Hi Guys! Does anyone know how to do a hipped roof return on just one side of the gable? Is that possible?
Hipped Roof returns
Started by
Guest_Zach_*
, Nov 04 2019 10:32 AM
Posted 05 November 2019 - 02:31 PM
Add a shed roof to each eave side of your gable(you need to change the peak of the shed roof to a "Vertical Intersection"). Now you have a gable roof where each side of the gable is independent. Simply edit the side you want to have the Hip return and you're all set. It is a little tricky getting the "Lollipops / suction cups" in roof mode to do what you want, so you'll have to play with them a little but does work.
- Ben Ginther, Jim Johnson, Bernard Toews and 2 others like this
