Has anybody tried to export SOFTPLAN files to REScheck-Web site. One of my local building authorities is requiring me to use 2018 IECC which is only available on the web, not an application that is downloaded to my computer.
Exporting SOFTPLAN files REScheck-Web
Posted 14 December 2019 - 02:17 PM
Yes. IF you have your model build correctly, all walls,ceilings, floors etc. The correct windows, door etc.
Export the rescheck script then open it in rescheck. It should all be there. You pick the code in sp and in rescheck. Both with have a check box for 2018 IECC.
Doing a commercial project in Comcheck is more involved. After loading into rescheck print a copy and then enter by hand into Comcheck. Much slower but you save all the measuring and calculating.
#5
Posted 16 December 2019 - 01:23 PM
You have to install the windows version of rescheck.
Then you can export your project as a 2015 version rck file.
Then login to the webversion and import that rck file.
You can then edit the imported project from 2015 to 2018 and look at the results.
- John Jones and David Zawadzki like this
