9-lite exterior doors
Exterior Doors
#1 Stephan Page
Stephan Page
  • 91 posts
  • LocationMaine
Posted 31 December 2019 - 01:14 PM
Is there anyway to show a 9-lite exterior door?  I'm new to Softplan and i'm probably missing something simple.
Stephan
#2 Richard Rubinski
  • 604 posts
Posted 31 December 2019 - 02:29 PM
Stephan
Stephan, I copied my  6-lite Dutch Door and edited it to have 9 lites, which it shows in the library. When I insert it into my drawing for some reason it still shows 6 lites. Maybe someone else can explain why this is happening.
Rick
  • 5,092 posts
Posted 31 December 2019 - 03:10 PM
Yes ... Someone can ...
The problem is that the "DUTCH" door 3D model has been designed as a six light door (Why? ... Who knows?) ... I've never actually seen a 6 light door like that. Although we use MANY 9 lights.
The easiest way to get round it, is go into the DRAWING LIBRARY > ELEVATION OPENINGS > DOOR > DUTCH and edit it ... and uncheck LINK TO 3D MODEL. Once you've done that, the drawing will no longer pull up the 3D model, and will revert to an enhanced opening, and will allow you to edit the grilles as usual. If you want to make the changes permanent, then go into the SYSTEM LIBRARY and make the same changes.
  • Stephan Page likes this
#4 Jon Davis
Jon Davis
  • 541 posts
Posted 31 December 2019 - 03:24 PM
Why can't you just edit the grill like you do for windows? Usually works for me... ??
  • 5,092 posts
Posted 31 December 2019 - 04:06 PM
It doesn't work with that door, because the 6 light grille is in-built into the 3D model of the door. If it was just glass then the software could supply the grilles, but it isn't, the grille is actually part of the linked model.
  • Jon Davis likes this
#6 Jason Bishop
Jason Bishop
  • 294 posts
Posted 01 January 2020 - 12:05 AM
One would think as this is the logical way to do it, but alas, Keith is right.
You have to go around your elbow to touch your nose......and it’s absurd.
  • Michael Landry likes this
#7 Stephan Page
Stephan Page
  • 91 posts
  • LocationMaine
Posted 07 February 2020 - 10:31 AM
Awesome!!!  I was able to follow your notes and change as you said Keith!  Thanks for the help!
