Intersecting rooflines
#1 Guest_Marianne La Nasa_*
Posted 11 January 2020 - 03:54 PM
Does anyone have a problem when you have roof lines that intersect, and the eaves/soffit of one shows through the ceiling of your finished rooms?
Also, I'm in the Sioux Falls, SD area and would love to hear from fellow Sioux Falls Softplan users.  I work for a builder and am teaching myself how to use Softplan in the hopes of getting him to use it.
Thanks!
#2 Steve and Carla Farnam
  • 680 posts
Posted 12 January 2020 - 08:57 AM
Marianne, where the roofs intersect you will want to cut out the portion of the roof that is not needed.
After cutting out the roof area edit the hole and uncheck the show soffit and facia box, this should delete
the roof that shows inside the finish rooms. To cut the roof hole go to Draw>Hole>Trace Hole, enable the snap tool
and trace the hole. After tracing the hole if some unwanted roof still appears zoom in on the edge of the hole and
you may have to adjust the hole to complete the cut out
#3 Guest_Marianne La Nasa_*
Posted 14 January 2020 - 01:49 PM
Thank you!  I'll give that a try!
