Hey All,
Trying to duplicate the railing in the attached image. Softplan has the option to add a railing cap, but it just adds the cap on top of the current rail with no option to offset.
Any suggestions?
Eric Muntz
Posted 20 January 2020 - 11:14 AM
Make a custom handrail profile that includes both top rails
Posted 20 January 2020 - 11:15 AM
I include the lower and mid rail as a standard handrail with extended posts then add a second rail system with only the top rail turned on.
Posted 20 January 2020 - 01:44 PM
Here's an update.
I used Martin's option, so there are two railings drawn there. It wasn't all that east to add a railing on top of the other. I will make an attempt at a custom handrail profile next time as Keith mentioned.
Thanks guys.
Posted 28 March 2020 - 09:50 AM
How do you make custom exterior rails with horizontal cables? Now that the code in BC has changed to be inline with the national code which allows horizontal rails/cables I’m getting requests from builders to have something different.
in the past ver 8-14 I would simply draw lines on a 2d elevation but with 2020 I’m trying todo more 3D stuff, but finding these things frustrating, not to mention all the other “work arounds” lol, really like this forum for getting help.. thanks
Posted 28 March 2020 - 12:28 PM
You can edit your railing and design as you like. Use round spindles and set them to horizontal. Change the spindle finish to one of the numbered finishes and then change the texture in 3D. Once designed, you can Add Definition so you will have it next time.
SoftPlan →
General Questions →
Railing Post Height DIfficultyStarted by Shay Bashaw , 18 Sep 2017 railing, post, height |
