Just installed Softplan 2020 I'm a neophyte . When I add auto roof to a simple drawing it doesn't appear in Softlist. Include in Sopftlist is checked
Softlist
Posted 04 February 2020 - 07:49 AM
Steve is right, you have to add the framing, which it will do automatically as well. On your plan, under the "roof" section, there's a tab that says "framing" click that, then "auto stick frame"
You'll need to go into project settings first though and set the spacing you want for your rafters or your count will be wrong in softlist.
This can be done locally (this project only) or system wide...
For this drawing only go to the file button, top left corner. > Drawing options >Drawing options>use custom drawing options>material dimensions>roof options>and set framing spacing to whatever your contractors usually frame (default is 16" OC)
To do this system wide, you will need to close your drawing, and repeat the same steps however start with System Options>System Options> etc..... This will ensure going forward that any new project you create will use the new framing spacing you want. It will not however, change already created projects. You'll have to use the steps above to change them.
