Print Elevation Drawings in Color
#1 Bobby Mercer
Bobby Mercer
  • 18 posts
Posted 05 February 2020 - 05:04 PM
I am using Roofing B as paint pattern on Front Elev. drawings.
I want to give it a light color just to make drawing look better on plans and Brochure.
Can someone tell what the process is.
For some reason I can't even get my title block to print in color anymore.
I'm sure its something simple I've undone or forgot to do.
Thanks for your help.
#2 Steve and Carla Farnam
  • 680 posts
Posted 05 February 2020 - 10:43 PM
Bobby, Under paint, same location you found the shingles, choose a color
to paint the roof, edit the color and adjust the opacity to desired look.
#3 Bobby Mercer
Bobby Mercer
  • 18 posts
Posted 06 February 2020 - 08:20 AM
Thanks Steve and Carla
I am using version 2018.
Under paint I do not have the option that I can see to choose colors.
I can adjust the colors and pens from the drawing to get the effect I want.
I figured out last night to check the box to use screen colors from the print menu.
That gets me what I want.
I guess I will have to play around with pen and color settings and save to system options.
#4 Steve and Carla Farnam
  • 680 posts
Posted 06 February 2020 - 09:22 AM
Bobby, In 2018 under the paint drop down choose solid and apply the color over the shingles and adjust opacity
#5 Bobby Mercer
Bobby Mercer
  • 18 posts
Posted 06 February 2020 - 01:26 PM
Thanks, having the two colors gives a better effect than adjusting just the shingles.
#6 Tracy Guest
Tracy Guest
  • 32 posts
Posted 07 February 2020 - 07:43 AM
Another option when selecting paint is to choose 'image'.
You select the material image from within your 3D/textures folder and adjust the opacity accordingly.
(screenshot example attached - the opacity was set to 20)
I guess it depends on the look you're trying to achieve. :)
#7 Bobby Mercer
Bobby Mercer
  • 18 posts
Posted 07 February 2020 - 09:49 AM
Thanks Tracey
