Opening project from the cloud, if they don't show in the list....
14 replies to this topic
#1 Jon Davis
Jon Davis
  • 541 posts
Posted 04 March 2020 - 07:39 AM
How do I do that??? I need to open a project that's in the cloud, b/c our server is down this morning.
But it's not in the list on the home screen... how do I get to it?
#2 Jon Davis
Jon Davis
  • 541 posts
Posted 06 March 2020 - 07:39 AM
no one? I searched the forum and found nothing. Even googled it and found another forum about softplan and nothing was there either... A search of
the softplan website didn't produce anything either.
#3 Dennis Hilborn
Dennis Hilborn
  • 816 posts
  • LocationDFW Texas
Posted 06 March 2020 - 08:36 AM
Did you send a question to support?  Direct access to the cloud might be a necessary upgrade.
#4 Mark Petri
  • 1,507 posts
Posted 06 March 2020 - 01:47 PM
If you share it with another key or a computer that is not part of the office system you may be able to find it and download it. We use Dropbox, so it is always available on any device or computer.
#5 Jon Davis
Jon Davis
  • 541 posts
Posted 07 March 2020 - 07:45 AM
no, my key, on my laptop.... i upload to the cloud for this reason... the other day our server went down but I still needed to work on drawings....
They are all in the cloud but it was one that didn't show in the list that I needed.
#6 Brent Hyndman
Brent Hyndman
  • 1,549 posts
Posted 09 March 2020 - 10:25 AM
Hi Jon.
I looked for a ticket or call to support and was unable to find one. I'd suggest contacting support if this is still an issue.
We will need the name of the project and the key number that you used to create/save the project to the cloud in order to confirm that it is saved there.
  • John Jones likes this
#7 Jon Davis
Jon Davis
  • 541 posts
Posted 09 March 2020 - 11:07 AM
Hi Jon.
Brent, I know it's saved there. I can't narrow this down to one project, as I may have to open multiple projects in the future that are saved in the cloud but are pushed too far down the list to show on the home page anymore....
I would think this would be a simple yes or no answer... Either, yeah you can open from the cloud even if it's not in the list and here's how to do it, or no you can't....
Posted 09 March 2020 - 11:16 AM
You know that list on the home page scrolls don't you? It should go back a long long way.
  • John Jones and Brent Hyndman like this
#9 Jon Davis
Jon Davis
  • 541 posts
Posted 09 March 2020 - 11:29 AM
Yep, and it wasn't listed there. I scrolled all the way to the bottom and back several times.
I've got 30-40 projects on my job board at any given time usually... So sometimes things get bumped down pretty quick.
#10 Brent Hyndman
Brent Hyndman
  • 1,549 posts
Posted 09 March 2020 - 12:57 PM
When I scroll the entire list of projects on my start page that have been saved to the cloud, the number matches the number that are actually on the cloud.
I also tested saving a project to our server then I disconnected from the server. The project, which was successfully uploaded to the cloud was available on my start page and downloaded from the cloud properly.
Please submit a ticket next time a project does not appear on your start page which you believe has been successfully uploaded to the cloud. Once again, we will need you to confirm the key number used and the exact name of the project.
#11 Jon Davis
Jon Davis
  • 541 posts
Posted 09 March 2020 - 02:17 PM
So the answer to the question "Can a project be opened from the cloud if it doesn't show in the list" Can't simply be answered with a yes or no?
#12 Dennis Hilborn
Dennis Hilborn
  • 816 posts
  • LocationDFW Texas
Posted 09 March 2020 - 02:31 PM
Shouldn't EVERY project you have loaded to the cloud be in the list?
#13 Brent Hyndman
Brent Hyndman
  • 1,549 posts
Posted 09 March 2020 - 02:59 PM
Jon.
If the project was successfully uploaded to the cloud it should appear on the start page. That is where you access files saved to the cloud. That said, if the file is not on the list, it is not on the cloud either.
The questions I asked on your ticket were in an attempt to determine why you believed cloud files were not appearing on your start page.Without the missing project names, and project count from your start page we don't have the information needed to determine if there is an issue or not.
#14 Jon Davis
Jon Davis
  • 541 posts
Posted 09 March 2020 - 03:08 PM
That's what I was trying to find out.
#15 Jon Davis
Jon Davis
  • 541 posts
Posted 09 March 2020 - 03:11 PM
Jon.
That's what I wanted to know.
Also. Will that list continue to populate through time? At some point, that list could end up showing 100's of projects in it correct? Or does it have a limit? If in a year from now I need to pull up a project that I worked on, and bam, our server is down that day for some reason, I should be able to scroll far enough back, to see that project in the list correct?
I have a feeling, it isn't going to be that simple.
