I'm sure this is simple but for some reason I have a 4" gap between the first and second floor in my model. Reference point is aligning and the offset for the wall is the truss depth plus decking I am stumped. It does not happen all the time.
#9
Posted 13 March 2020 - 10:23 AM
Yes if you have a first floor wall that is taller than the rest, then the second floor is going to reference off the tallest wall....
Not if you use the circular reference point. The circular reference stacks at the heights specified at the reference point.
Have a look at this post ... http://softplan.com/...f-house/?p=5596
Posted 14 March 2020 - 04:53 AM
The circular reference point is the one you want to use. It will pull the floors together, both horizontally and vertically, at that location. Make sure the walls at that location, on each floor, have the same height and the same offset. They can be different from floor to floor as long as they are the same on each location.
#14
Posted 14 March 2020 - 09:41 PM
When models get complicated it is sometimes best to set walls you can hide and not extract in 3D away from the model and set the reference point on those walls to keep the offsets clean. Whatever heights you set those walls to will dictate the stacking of drawings and can lessen the possibility of messing up with walls raking, fitting to soffit, or anything else you make do in the actual building model.
- Heath Foster likes this
#15
Posted 16 March 2020 - 05:50 AM
It's whatever elevation the wall is that you put the reference point on. If you put it on a wall that's offset for some reason, everything that stacks will pull to that elevation.
Cool... I didn't know that. Typically all my walls are the same height but, I'll have to remember this for future models.
Also tagged with one or more of these keywords: Model
SoftPlan →
General Questions →
Sheathing Doesn't Model?Started by Derk Burgers , 15 Mar 2023 wall sheathing, sheathing and 4 more... |
SoftPlan →
SoftPlan 2018 →
Fascia gone?Started by Mark Petri , 05 Apr 2018 Roofs, Fascia, Trim, 3D, Model and 1 more... |
SoftPlan →
SoftPlan 2014 →
Assemble Floors Button Stopped WorkingStarted by Pamela Nacke , 19 Apr 2016 elevations, assemble floors and 1 more... |
