Why the Gap
Model
15 replies to this topic
#1 GENE GILES
GENE GILES
  • 81 posts
Posted 12 March 2020 - 11:56 AM
I'm sure this is simple but for some reason I have a 4" gap between the first and second floor in my model. Reference point is aligning and the offset for the wall is the truss depth plus decking I am stumped. It does not happen all the time.
Gene
#2 Jon Davis
Jon Davis
  • 541 posts
Posted 12 March 2020 - 12:23 PM
Did you draw a slab on the first floor? If so, set it to offset 4" down.
#3 GENE GILES
GENE GILES
  • 81 posts
Posted 12 March 2020 - 12:40 PM
Hey Jon - It's on a crawl space (Flood Area) so the first floor is 2"x12"  so the offset is set to that.
Gene
#4 Henry Buckner
Henry Buckner
  • 342 posts
Posted 12 March 2020 - 12:56 PM
Are the 1st floor walls all the same height?
#5 GENE GILES
GENE GILES
  • 81 posts
Posted 12 March 2020 - 01:08 PM
Hey Henry - No they vary
Gene
#6 Henry Buckner
Henry Buckner
  • 342 posts
Posted 12 March 2020 - 01:14 PM
I asked because if the reference point is higher than the zero for the 2nd floor everything else will be too.
#7 GENE GILES
GENE GILES
  • 81 posts
Posted 12 March 2020 - 01:18 PM
I moved the reference a couple times let me give it a try again
Gene
#8 Jon Davis
Jon Davis
  • 541 posts
Posted 13 March 2020 - 09:42 AM
Yes if you have a first floor wall that is taller than the rest, then the second floor is going to reference off the tallest wall....
#9 Keith Almond
  • 5,098 posts
Posted 13 March 2020 - 10:23 AM
Not if you use the circular reference point. The circular reference stacks at the heights specified at the reference point.
Have a look at this post ... http://softplan.com/...f-house/?p=5596
#10 Jon Davis
Jon Davis
  • 541 posts
Posted 13 March 2020 - 12:53 PM
I didn't know you could set an elevation at the reference point.
#11 Henry Buckner
Henry Buckner
  • 342 posts
Posted 13 March 2020 - 01:08 PM
It's whatever elevation the wall is that you put the reference point on. If you put it on a wall that's offset for some reason, everything that stacks will pull to that elevation.
  • Jon Davis likes this
#12 Don Gibbons
Don Gibbons
  • 375 posts
Posted 14 March 2020 - 04:53 AM
The circular reference point is the one you want to use. It will pull the floors together, both horizontally and vertically, at that location. Make sure the walls at that location, on each floor, have the same height and the same offset. They can be different from floor to floor as long as they are the same on each location.
#13 GENE GILES
GENE GILES
  • 81 posts
Posted 14 March 2020 - 11:47 AM
The fit to roof was throwing my reference walls off. Thanks for the help all.
Gene
#14 Mark Petri
  • 1,511 posts
Posted 14 March 2020 - 09:41 PM
When models get complicated it is sometimes best to set walls you can hide and not extract in 3D away from the model and set the reference point on those walls to keep the offsets clean. Whatever heights you set those walls to will dictate the stacking of drawings and can lessen the possibility of messing up with walls raking, fitting to soffit, or anything else you make do in the actual building model.
  • Heath Foster likes this
#15 Jon Davis
Jon Davis
  • 541 posts
Posted 16 March 2020 - 05:50 AM
Cool... I didn't know that. Typically all my walls are the same height but, I'll have to remember this for future models.
#16 GENE GILES
GENE GILES
  • 81 posts
Posted 17 March 2020 - 04:46 PM
Great Tip Mark that's what I ended up doing.
  • Mark Petri likes this
Gene
Also tagged with one or more of these keywords: Model
