water marks
7 replies to this topic
#1 Jonathan Barto
Jonathan Barto
  • 131 posts
  • LocationPittsburgh, Pa
Posted 25 March 2020 - 06:18 AM
In regards to watermarks..
1.  Is there any way to tighten up the spacing on the watermarks?
2.  Is there any way to change the colors so it darker or even like red?
  • Allen McDonnell likes this
#2 Jon Davis
Jon Davis
  • 541 posts
Posted 25 March 2020 - 07:11 AM
I don't see anyway to edit the one's in place. You may can create your own?
#3 Jonathan Barto
Jonathan Barto
  • 131 posts
Posted 25 March 2020 - 07:14 AM
Ya I did create my own.  But dont know how to edit it in regards to my 2 questions
#4 Allen McDonnell
  • 955 posts
  • LocationIllinois
Posted 25 March 2020 - 08:45 AM
Great question Jonathan.
I would appreciate an enhancement in the water mark category.  Your two questions have been asked repeatedly by builders of mine.
#5 Martin Wrobel
Martin Wrobel
  • 82 posts
Posted 25 March 2020 - 11:18 AM
I put a watermark on my drawings using Foxit and Adobe. Foxit is a very good PDF editor and affordable. I don't care for the way Softplan does the watermarks.
  • Jon Davis likes this
Martin Wrobel
Superior Home Design
Michigan
Softplan 2024
Posted 25 March 2020 - 05:48 PM
You can't tighten up the spacing or use colour as far as I can tell. I tried using a colour on the text, but once it's a symbol it seems to revert to standard symbol colour, and you can't edit it as a symbol. Didn't try to edit the symbol in the library, so you may be able to edit it that way. Must do some more experimentation!
You can't tighten up the spacing, but if you make your own custom text (Custom font and size), you can make the font big enough to fill the spaces more.
#7 Dennis Hilborn
Dennis Hilborn
  • 816 posts
  • LocationDFW Texas
Posted 26 March 2020 - 05:50 AM
I don't use watermarks, but lately wine marks are what I've been using.
On second thought.
I have not used the watermark feature but I think this would work.  Create a drawing using the color, style etc. the way you would like it to look.  Set up your sheet the drop your "watermark" drawing on top of each sheet.  It's not automatic but it should work and you would have total control over the details rather than limited.
#8 Mark Petri
  • 1,510 posts
Posted 26 March 2020 - 07:31 AM
Good solution Dennis!
