Cathedral porch gable
8 replies to this topic
#1 Bryan Schultz
Bryan Schultz
  • 68 posts
Posted 25 March 2020 - 06:30 AM
How do I fill in the gable on this porch with the cathedral ceiling? I tried adding a wall with Rake top fit to roof and rake bottom - no luck. Any help would be appreciated.
#2 Bryan Schultz
Bryan Schultz
  • 68 posts
Posted 25 March 2020 - 07:00 AM
Sorry, I forgot to attach the image.
#3 Brendan Smythe
Brendan Smythe
  • 86 posts
Posted 25 March 2020 - 09:13 AM
Bryan,
That's a good question, I have been wondering how to fill that space for quite some time also. In recent times, we have gone away from the scissor truss in favor of the parallel chord truss. This way I can now use the frieze board to cover that opening.
#4 Ben Ginther
Ben Ginther
  • 141 posts
  • LocationSaskatchewan
Posted 25 March 2020 - 10:55 AM
I have offset a wall to top plate of main walls and added a triangle window so I can always adjust the width and height needed. Then I do not display the framing, glazing, and bead but can still add Exterior frame.
Posted 25 March 2020 - 11:12 AM
You can also do it with 2 walls ... meeting in the centre ,,, That way you can rake top and bottom and adjust to suit with the heights in the multi height section.
#6 Martin Wrobel
Martin Wrobel
  • 82 posts
Posted 25 March 2020 - 11:20 AM
Ben
I have never thought to use a window for this application. I keep learning new things from the forum.
Martin Wrobel
Superior Home Design
Michigan
Softplan 2024
Posted 25 March 2020 - 05:53 PM
... In recent times, we have gone away from the scissor truss in favor of the parallel chord truss. This way I can now use the frieze board to cover that opening.
If you're using parallels then you can add a ceiling to match and make it extra thick. I've even added 2 ceilings. one thin to give a ceiling finish inside, and one thick to show a different finish on the gable.
  • Brendan Smythe likes this
#8 Bryan Schultz
Bryan Schultz
  • 68 posts
Posted 26 March 2020 - 08:39 AM
Softplan also suggested the 2 wall approach.
Thanks everyone for your responses!
#9 Brendan Smythe
Brendan Smythe
  • 86 posts
Posted 31 March 2020 - 02:42 PM
Brilliant!!
