How do you remove lines generated by walls butted together? (cloud circled)
I've changed wall joins to 0", taken out of clean up, nothing works
Is there a better way to do step foundations without separating the wall sections?
Posted 31 March 2020 - 01:48 PM
I had something similar happen to me. I created a 'ticket' and this is the response I got from tech support:
Switch your elevation view back to Model mode, then select Options > Mode Options > Line Options > and enable Silhouette to resolve these lines. Then switch back to Annotated mode.
I hope this helps!
