I have a set of stairs on a project that has a lower set of stairs, a midway landing, and an upper set of stairs.
Everything shows up just fine in 3D view, but if I generate an ELEVATION VIEW, the landing does not show.
The stairs show, but the landing does not show.
I check my extraction options and even checked floor framing to show, and it did not show the landing. I read in the help section, that landings are basically floor framing members, so I thought that would do the trick. I checked that they were selected to show in the "model" and it is checked by default and greyed out.
I know I can draw a solid cube to represent the landing, but it seems to me that they should show by default.
I also know I can draw a section line in front of the project and generate a section with background to act as an elevation view.
These are all work arounds (which I have done many times) because I always seem to have this same issue.
What am I missing?
I have attached the 3D view which does render the landing....I just want it to show when I generate a front elevation by default.
Tommy
