I'm redrawing a plan that was drawn before we started drawing. We have built this house twice and I need to adjust the space below the inside of the main floor linen closet to create head room on the stairs. When we built it, we build a raised floor inside the linen closet by 12-18".
I attached some screenshots. I have drawn a floor system in inside the closet but every time I try explode and change the joist size, or anything else, it changes it for the entire house. I thought about setting a different level but not sure if that will work or if it will change the entire house.
The ultimate goal, is to raise the subfloor inside the linen closet while still allowing the stair hole to have sheetrock and sheetrock the bottom side of howver it is drawn to raise the linen closet floor so the rendering looks good down below when we add a ceiling.
I know how to build it I just don't know how to draw it and get it to render correctly. If we were only doing 2D prints it wouldn't be an issue but I plan to do some fly through videos of this plan for marketing purposes.
Thanks in advance!
