Did you know | Tray and Vaulted Ceilings
7 replies to this topic
#1 Jim Henderson
Jim Henderson
  • 239 posts
Posted 11 May 2020 - 10:47 AM
YouTube Link: https://youtu.be/yjcphiGDFjI
This video will step you through creating three different custom ceilings, including two different tray ceilings as well as a vaulted ceiling with ceiling trusses.
  • Heath Foster, Tom Rogers, Brent Hyndman and 1 other like this
#2 Harlon Suttle
Harlon Suttle
  • 383 posts
  • LocationOverland Park, Ks
Posted 11 May 2020 - 11:06 AM
How about circle, or elliptical "Tray" ceiling areas below the main ceilng ?
Harlon G. " Buddy " Suttle
casekc49@gmail.com
CELL: 913-339-6242
#3 Jennifer Emmons
Jennifer Emmons
  • 4 posts
  • LocationPace, FL
Posted 12 June 2020 - 11:18 PM
Adding ceiling trusses to a vaulted ceiling - ceiling trusses show up in ceiling mode plan view, but do not show up in the 3d model view.  I thought I needed to check the "extract in model" box in the edit command, but the option is already checked and grayed out.  Are there any other settings I'm missing?  Thanks!
#4 Jim Johnson
Jim Johnson
  • 289 posts
Posted 13 June 2020 - 10:08 AM
In the 3D view, go to "Options>Material" and make sure they are set to display there.  You will find them under "Structure".
#5 Henry Buckner
Henry Buckner
  • 342 posts
Posted 13 June 2020 - 10:46 AM
They need to be checked in "Extraction Options- Framing-Roof Framing" also
#6 Gary McKeon
  • 557 posts
Posted 14 June 2020 - 10:21 AM
And that is a beef of mine. Why in the world would anyone have to know that you have to go "here" and then "there" in order to see something? Doesn't make sense and is terribly inefficient and that isn't even including the frustration experience for people who are learning the program! Could and should be much simpler to have the same level of control.
#7 Jennifer Emmons
Jennifer Emmons
  • 4 posts
  • LocationPace, FL
Posted 15 June 2020 - 05:32 PM
Thanks for your responses.  The extraction options>framing solution worked did the trick!
Posted 15 June 2020 - 06:34 PM
Normally, the Materials default to ON ... Typically, you have too explicitly go in an turn display OFF. After that, you're on your own.
