below grade
1 reply to this topic
#1 Jonathan Barto
Jonathan Barto
  • 146 posts
  • LocationPittsburgh, Pa
Posted 13 May 2020 - 08:50 AM
Is there any way to calculate water proofing on a foundation wall.
Say the lot slopes to a full walk out in the rear so some of the foudation will be out of the ground.
is there a way to write a formula to show how much is below grade?
Also is there a way to calcuate stone or brick that would be above grade?
I would have grade lines drawn in on the site plan to correct finished grade.
#2 David Zawadzki
  • 733 posts
Posted 13 May 2020 - 01:41 PM
Have you tried different wall definitions for above and below grade?
