Survey Import
survey site site plan
#1 Derk Burgers
Derk Burgers
  • 91 posts
  • LocationSioux Center, Iowa
Posted 14 May 2020 - 04:01 PM
Hi all,
As a lumber yard draftsman in NW Iowa (flat ground for the most part) I don't often get involved in site plans. Typically the builder and foundation contractor go out with a transit and figure out elevations themselves. On this project, though, they hired a survey done and would like me to import the survey into the model -- what file type should I have the surveyor export to me?
Derk
#2 Mark Petri
  • 1,874 posts
Posted 14 May 2020 - 04:36 PM
I've never had great success getting more than the 2D line work from surveys (usually DWG). But, I think there is a way to import and retain the grade lines for 3D. I've had better success importing to SketchUp and creating a draped surface on the grade lines there. Then, I export as a symbol to SP. I think someone will have a better way though.
#3 Rannie Kean
Rannie Kean
  • 15 posts
Posted 14 May 2020 - 04:37 PM
Derk,
Use the File Menu at the top left corner of the screen. Select the Import/Export command and choose the Import .dwg feature. Import the file onto your drawing. It should display in a cyan color. Use the color that you normally use for drawing.
You will have to trace your site drawing over the imported file to produce your SP drawing.
Good luck.
#4 David Zawadzki
  • 736 posts
Posted 14 May 2020 - 11:37 PM
https://youtu.be/_tIPLflhkoo
See if this video works for you...
  • Mark Petri likes this
#5 David Zawadzki
  • 736 posts
Posted 15 May 2020 - 12:55 PM
Here is another tutorial I found for you:
https://softplan.com...V9QbGFucy5tcDQ=
#6 Brian Berzinskis
Brian Berzinskis
  • 474 posts
  • LocationNew Jersey
Posted 19 May 2020 - 10:29 AM
I usually get the survey files sent over to me as DWG but I must admit I usually have to do a decent amount of clean up.
Some guys send me files that have other surveys in it off to the sides. Not sure what their file management techniques are.
Also tagged with one or more of these keywords: survey, site, site plan
