How are you all approaching your marketing floor plans? I usually save the floor plans as a different drawing and turn off the items as needed. But, I have to think there's a better way to approach it. Thanks in advance for the help.
Marketing Floorplans
Posted 19 May 2020 - 10:25 AM
Currently I save it as a different file and erase out the information that I don't need. But I really should be doing it in a Custom Drawing Mode if I had the time to set it up. I don't know if there is a way though to show only Exterior Auto Dimensions in a Custom Drawing Mode. Because I usually erase all interior dimensions and just have the room names with their dimensions for marketing.
#5
Posted 19 May 2020 - 11:10 AM
If you set up a custom mode, does anyone know how to show the walls solid like Room mode shows them. I've looked in the past, and can't find it. I assume I'm missing something fundamental.
But, even so if you want to do marketing plans a custom mode is the way to go. Just set everything up once, and switch modes to show whatever you want.
Posted 19 May 2020 - 03:35 PM
What about the Presentations Views already in SoftPlan?
#12
Posted 19 May 2020 - 06:18 PM
Keith - It's in the bottom area (upper left corner of that bottom space) of the visible items menu - just check the box for "show/print walls solid".
Thanks Mark,
I don't know why, but I always assumed that that was a toggle, and worked the same way as the "DISPLAY EVERYTHING" switch. I didn't realize it was controllable independently from the mode area's.
Good to know.
In that case all you people saving files as different drawings and deleting things should definitely look into creating a custom mode for your marketing plans that just switches everything on/off as necessary with a single switch. Would be much easier.
Posted 19 May 2020 - 06:26 PM
You can adjust the presentation view just like your other views...
#14
Posted 19 May 2020 - 06:35 PM
Here is visible lines presentation view:
#15
Posted 20 May 2020 - 09:17 AM
Here is the same presentation view in textured mode with lights off:
#16
Posted 20 May 2020 - 09:43 AM
I guess it's which way you prefer. If you don't define each room like hallways, closets, ect it isn't as clean as yours. Bill over at Softplantuts showed me this way. Once you set it up all you have to do is change it to the Presentation mode.
https://softplantuts...ING-FLOOR-PLANS
- Mark Petri likes this
#17
Posted 20 May 2020 - 11:40 AM
Here is a quick marketing flyer using an 8x11 layout template and data stamps:
- Gary McKeon and ROBERT BROGAN like this
