I give up looking Richard, where is "include in Rescheck"?
Never mind. I found it under Softlist option.
The problem I have though is that I have to create a whole drawing sheet to provide all the energy information for Rescheck and Manual J where most of my plans are submitted for permit. I have to show the building envelope also, room dimension and areas, ceiling areas, wall areas, etc. Also there are times that an exterior wall may have a height of 10 feet but a celling height of 9 feet for example. The wall would be modified in my separate drawing to 9 feet to capture the proper exterior wall area.
The reason for all the detail is that many builders were cheating on the insulation package by falsifying the Rescheck. When I run the Rescheck I specify all the energy parameters and then some builders would not pass, so they had others run the Rescheck and adjust their hard input information to get a passing Rescheck but it was a false report. So the chief inspector put an end to that requiring a great deal of detail so the builders can be checked properly in the field. Imagine that, builders that cheat.
