I am working on a fix for a garage that is sliding into a ravine. The engineer has designed a retaining wall at the end of the garage that has a offset footing that is 8'-6" wide with 1'-6" on the outside of the 12" thick conc. wall. Standard stuff. Softplan wants to have the footer extend past the end of the wall 7'. I want the footing to end 1'-6' past the end of the wall. Is there a work around?
EDITING ENDS OF FOUNDATION FOOTINGS
Posted 29 May 2020 - 09:11 AM
Or use a solid cube. Unfortunately we do not have the control we need for such situations. But, you can also take care of it with a wall definition including the footing as part of the actual definition, but then it will only stay the exact length of the wall you draw. I often use a solid cube or polygon for such things. And, on occasion I use walls I set up as just footings, nothing else.
- Jim Johnson likes this
#8
Posted 05 June 2020 - 03:56 PM
John attached shows 10" Concrete wall that was exploded once,
footing lines erased leaving the wall only. A cube drawn ( left blue
for illustration) to desired footing size and offset for 3D illlustration.
The cube in 2D was edited so lines match 2D footing line style.
Set cube profile to one not used in the drawing and copy/paste
wall concrete to match for 3D, shown in 3D attached.
JUST READ MARKS ABOVE, What Mark said.
