is there a way to find a trapezoid window i am design one now i try to find one in symbols with no luck i would like to be able to edit it for matching the roof pitch
dose any one have any help for this
thanks Ron
Posted 01 June 2020 - 03:43 PM
If it is a trapezoid it is set to follow the wall or ceiling by default. If you don't want it to do either you need to tell it. Go to the miscellaneous tab in the window edit menu and tell it to slope up to right or left and set the pitch. If you have the width and the pitch set correct you should get the numbers you want (or at least close).
Posted 29 June 2020 - 03:30 PM
Steve i did that but i cant get a leg on the short end like 2' on one and 4' up on the tall end unless i am missing something
thanks Steve
Did you ever find a resolve to get the 2' leg on one side and the 4' leg on the other side? I'm trying to accomplish that myself right now and am not having much luck!
