Splines
#1 Kevin Rabenaldt
Kevin Rabenaldt
  • 391 posts
  • LocationSan Antonio
Posted 25 June 2020 - 11:00 AM
Is there a way to turn off the red squares or reduce the size of the squares on a spline?  I have the need to draw some small and smooth splines so I drew them at four times the size needed then used adjust to reduce back down.  Problem is the red squares make it hard to move the spline where needed.
#2 David Zawadzki
  • 643 posts
Posted 25 June 2020 - 11:24 AM
Are you talking about the snap indicators?
#3 Kevin Rabenaldt
Kevin Rabenaldt
  • 391 posts
Posted 25 June 2020 - 12:00 PM
The manual calls them red boxes.  They are the nodes to the spline that are used to adjust the spline.  I need them to be turned off for the screen view.  They of course do not print but they have crowded out the actual line.
#4 Jim Johnson
Jim Johnson
  • 289 posts
Posted 25 June 2020 - 12:12 PM
Drawing Options>Mode Visibilities> Uncheck "Show Non-Printable Items"
#5 Kevin Rabenaldt
Kevin Rabenaldt
  • 391 posts
Posted 25 June 2020 - 01:54 PM
Jim, thanks!  That is exactly what I needed.  I was definitely looking in the wrong places.
