Roof Color
#1 Jack Carson
Jack Carson
  • 143 posts
Posted 28 June 2020 - 11:04 AM
I am drawing a commercial building and I have a problem that I don't remember running into before.  The roof is flat (1/12) covered with TPO which is white.  I also have two small porches that have shingles.  When I add the shingles the flat room now has shingles.  So I color the roof white and the shingles on the porches turn white.  Any ideas?  I need to keep the roof white and the shingles colored.
Jack
#2 David Zawadzki
  • 660 posts
Posted 28 June 2020 - 11:08 AM
You need to change the material on one of your roofs to something other than what you have on the other roof.
 I hope that makes sense.
#3 Jack Carson
Jack Carson
  • 143 posts
Posted 30 June 2020 - 10:48 AM
David, I figured out what I was doing wrong. I created a flat roof that was white to represent TPO, and then two porch roofs.  It's a two-story building so the roofs were not connected. I created the first porch roof with blue standing seam roofing.  No problem.  I decided to just copy the first porch roof to the location of #2.  Everything copied except the blue standing seam room.  So I just surface copied it and that's when the TPO turned into a blue roof.  I turned the TPO white and the second porch changed to white.  Number one wasn't affected.  So I decided to delete the #2 roof, which I had copied and started new.  That solved the problem.  I hope this makes sense.
#4 Mark Petri
  • 1,511 posts
Posted 30 June 2020 - 11:03 AM
Jack, you can also select the roofing material in the roof edit menu, so you don't have to redraw the whole thing (for future reference).
  • Brent Hyndman likes this
#5 Jack Carson
Jack Carson
  • 143 posts
Posted 01 July 2020 - 05:13 AM
Thanks Mark!
