3 monitors/ "edit dimension" window hides
3 monitors/ edit window/ sett
#1 Jason Rodgers
Jason Rodgers
  • 11 posts
  • LocationCleveland, Ohio
Posted 03 July 2020 - 11:18 AM
I have my laptop set to "extend" to 3 monitors, see screenshot for settings.  When I go to edit, specifically a dimension, the "edit" window goes off the screen to monitor #1 or completely off all three screens where you can't see it or use it.  I have to change the settings to second screen only, then I can see it and then edit.  Anybody have this issue and know how to resolve it?
“Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic”
#2 Jason Bishop
Jason Bishop
  • 295 posts
Posted 04 July 2020 - 11:11 AM
Yes. Same issue. I have not found a solution.
#3 Keith Owens
Keith Owens
  • 96 posts
  • LocationConnecticut
Posted 05 July 2020 - 04:52 AM
Take a look at this thread. Should help you out.
#4 Jason Rodgers
Jason Rodgers
  • 11 posts
Posted 05 July 2020 - 09:14 AM
Thank you Keith.  I tried the steps in the additional thred.  It does move the window, but then if I open it again, it goes back to hiding. I will need to file a ticket I guess.
#5 Jon Davis
Jon Davis
  • 541 posts
Posted 06 July 2020 - 06:47 AM
It should open back up in the same place you pulled it to...  I still occasionally have this happen, and have to revert back to that thread to fix it.
#6 Dennis Hilborn
Dennis Hilborn
  • 816 posts
  • LocationDFW Texas
Posted 06 July 2020 - 07:00 AM
Jason, I had a similar problem with using three monitors.  But I was using them as separate monitors not extending my screen.
get SP set up the way you want then close SP and restart.  That might not help in your case but it's worth a try.
