Every time I print a 3D view using "visible lines" I spend 30 min's finding and manually drawing in the missing union lines where roofs meet roof and walls meet roofs. Those lines are VISIBLE lines and should print but they are left off. Some of my customers complain if they are not on the drawing. The drawing does not look right if they are not put on. I SHOULD NOT HAVE TO ADD THEM. And I'm tired of doing so. Please fix the problem.
Can we get the missing lines problem fixed?
Started by
Dennis Hilborn
, Jul 10 2020 03:51 PM
Posted 10 July 2020 - 11:34 PM
One tip I found, at least for a roof meeting a wall, is set it at intersect, vertical- not auto, and negative overhang to whatever the wall siding is (I use -1.5" for my wall definition).
It seems the issue, or part of it, is when 3d surfaces intersect each other?
Another thing this affects is fit to soffit, which can be good or bad depending on the situation
