Built-up LVL Beams
10 replies to this topic
#1 Mike Adams
Mike Adams
  • 278 posts
Posted 15 July 2020 - 01:45 PM
Its the little things..
I tried all the material types except one in Beam Definitions to create a 4 ply LVL beam that showed the plys  1.75'' wide instead of 1.5''.   The one I didn't try was Plate.  It now shows up clean in the cross sections as being 4 plys, 1.75'' x 11.875'' , tight together the way they are supposed to be.  Can't take the credit, it was Technical Support who helped.  There may be other ways, but this is a winner for me.
Stay Safe
Mike
  • Rick Kingsbury and Steve and Carla Farnam like this
#2 Kevin Rabenaldt
Kevin Rabenaldt
  • 391 posts
  • LocationSan Antonio
Posted 15 July 2020 - 06:12 PM
Really?  I have setup multiple LVL beams in creating new beams.  I specify the width and it gives the correct individual width.  I have setup single, double, triple, and quad.  Maybe I don't understand the issue you were having.
  • 5,310 posts
Posted 15 July 2020 - 08:02 PM
I use "built-up beams" and I don't have any issues. What was the problem?
#4 Mike Adams
Mike Adams
  • 278 posts
Posted 16 July 2020 - 04:20 AM
I said its a small thing.
  • Attached File  OLD.png   60.21KB   0 downloads
  • Attached File  NEW.png   30.72KB   0 downloads
#5 James Ronson
James Ronson
  • 14 posts
  • LocationOntario, Canada
Posted 16 July 2020 - 07:56 AM
I think (not very often) Mike is saying if you set the beam material to 1.75" thick, SoftPlan creates it in a section view at 1.5". I recall this happening in the past.
Good to know about using a plate to correct this.
Thanks!
#6 Mark Petri
  • 1,874 posts
Posted 16 July 2020 - 11:48 AM
I use solid wood beam for each ply.
#7 Dennis Asher
Dennis Asher
  • 247 posts
Posted 16 July 2020 - 12:16 PM
I have tried to make built up beams in the past with stucco on them as they would be done in the field.  I have never been able to get them to fillet properly so they looked good in 3d.
#8 David Zawadzki
  • 733 posts
Posted 16 July 2020 - 01:34 PM
Dennis, I’m not at my computer right now but isn’t there a check box to wrap beam with drywall?
Would that work for you if you then changed the material to stucco?
#9 Dennis Asher
Dennis Asher
  • 247 posts
Posted 16 July 2020 - 02:02 PM
I will sure give it a try.  Currently I have bee using a 12" tall stucco wall offset to truss bearing height.  It works for me since I'm not doing material takeoffs but the beam would sure be easier to work with...lol!
#10 Mark Petri
  • 1,874 posts
Posted 17 July 2020 - 08:44 AM
Or, make wall definitions that are just beams and stucco wrap. Then, you will need to use the offset entry to get the bottom of the beam where you want it, but all materials will butt or miter as intended. Only issue might be when intersecting a full height wall you may have to play with wall joins and such to get the siding to fill in correctly under the beam.
  • Jim Johnson and Dennis Asher like this
#11 Keith Almond
  • 5,310 posts
Posted 17 July 2020 - 11:05 AM
Wrapping beams doesn't work properly on corners, as it doesn't wrap the ends, and they don't show correctly in the model. Having options for the beam finish like the siding (A to E) would definitely make things easier.
  • Jim Johnson likes this
