Forgot..
8 replies to this topic
#1 Glenn Mitchell
Glenn Mitchell
  • 72 posts
  • LocationComox BC
Posted 28 July 2020 - 01:12 PM
My dimensions are red and do not respond to sizing changes. I've forgotten what that is about??
#2 Gary McKeon
  • 642 posts
Posted 28 July 2020 - 01:30 PM
You have manually changed the dimension text so it is no longer parametric. You will have to re-do that string to have it show the correct distance.
#3 Glenn Mitchell
Glenn Mitchell
  • 72 posts
  • LocationComox BC
Posted 28 July 2020 - 01:54 PM
Thanks Gary.
They are the right distances, just red and small.
One solution was to reboot the program but it would be nice to know how i did it. lol
#4 Richard Rubinski
  • 693 posts
Posted 28 July 2020 - 02:16 PM
Thanks Gary.
Looks like you edited the dimension and checked show text or rounded the dimension. If you uncheck show text it should go back to green.
#5 Glenn Mitchell
Glenn Mitchell
  • 72 posts
  • LocationComox BC
Posted 28 July 2020 - 02:21 PM
Huh! that does show up as red if you put in text as you say, but pretty sure I didn't do that as it requires a couple of inputs and all of them did it in all the drawings in the project.  It must be some sort of universal setting. Likely a key combo?
  • 5,298 posts
Posted 28 July 2020 - 08:13 PM
If you highlight ALL the dimensions with CTRL and then marquee select, you can uncheck them (or check them) all at once. You don't have to re-do any of the dimension strings.
#7 Glenn Mitchell
Glenn Mitchell
  • 72 posts
  • LocationComox BC
Posted 28 July 2020 - 10:59 PM
I guess I'm not understanding?
What single (accidental) command would make ALL the dimensions in ALL the drawings in a project go red and become non editable?
A command that is so temporary that a reboot fixes it?
Glenn
#8 Mark Petri
  • 1,871 posts
Posted 29 July 2020 - 09:26 AM
Only thing I can think of is you have them on a building option or layer that is colored red or locked and red?
#9 Keith Almond
  • 5,298 posts
Posted 29 July 2020 - 06:54 PM
Is it possible you hit CTRL-Q ... that would make them RED although they should still be editable (and bigger). Try CTRL-Q as a toggle and see what that does.
  • John Jones likes this
