Vertical Lattice in Elevations
18 replies to this topic
#1 Steven Kirchoff
Steven Kirchoff
  • 116 posts
Posted 18 August 2020 - 01:26 PM
I'm trying to figure out what I am doing wrong.
In 3D the lattice under the screen porch show up, but when I generate my elevation it is not there.
Can any one steer me in the right direction to make the lattice appear.
I would hate to draw it all in.
#2 Henry Buckner
Henry Buckner
  • 342 posts
Posted 18 August 2020 - 01:38 PM
Are you using a symbol?
#3 Steven Kirchoff
Steven Kirchoff
  • 116 posts
Posted 18 August 2020 - 02:08 PM
yes I used the symbol lattice vertical in miscellaneous
#4 Henry Buckner
Henry Buckner
  • 342 posts
Posted 18 August 2020 - 03:03 PM
Edit the symbol and open the "symbol definition" box. Check "Extract in elevation"
#5 Michael Landry
Michael Landry
  • 81 posts
  • LocationEaston, Ma.
Posted 18 August 2020 - 03:45 PM
Unrelated to the question you are asking, but don't you need some type of guard rail on the perimeter of the
screened porch?
#6 David Zawadzki
  • 733 posts
Posted 18 August 2020 - 05:18 PM
Is there a reason you don’t use the deck lattice in the edit tab?
#7 Steven Kirchoff
Steven Kirchoff
  • 116 posts
Posted 19 August 2020 - 02:12 PM
Got it to work Henry. Thank you.
Michael...The screen porch is existing and there is a guard rail I just didn't show it at this time.
I was fixated on getting the lattice to show on my elevation.
Thanks your your help.
  • 5,307 posts
Posted 19 August 2020 - 06:22 PM
Steven, (And anyone else interested), I've posted lattice before, but here's a few variations of a seamless lattice texture that I made.
If you create a wall from a little used material (I use cement board) and add these textures (check transparent) they show quite nicely on both the model and the elevations.
If anyone want's a specific colour let me know.
  • Heath Foster and Tom Rogers like this
#9 David Edlin
David Edlin
  • 45 posts
Posted 22 May 2021 - 08:05 AM
Hi Keith,
Are these lattice examples from Filter Forge? Can Filter Forge do stone seamless flagstone textures (Proper Oblong Flagstone textures and not the broken paving)?
Like Marshalls patio slabs.
Regards
David Edlin
#10 Keith Almond
  • 5,307 posts
Posted 22 May 2021 - 08:50 AM
It can certainly do square ones - these are 24" x 24".
There are various brick shapes, so I don't see any reason why oblong isn't possible. I'll have to experiment a bit.
Attached File  Paving Slabs - Offset.jpg   684KB   1 downloads
Attached File  Paving Slabs.jpg   668KB   0 downloads
#11 Keith Almond
  • 5,307 posts
Posted 22 May 2021 - 09:13 AM
After a bit of experimenting, how do these look. They should show as 24" x 30" on plan.
Attached File  Paving Slabs 24 x 30.jpg   186.6KB   1 downloads
Attached File  Paving Slabs 24 x 30 - Offset.jpg   186.48KB   0 downloads
and yes, they are done in Filter Forge. However, to keep them proportional at 5:4 I had to increase the image size and it became too big to post here, so I had to decrease the JPG quality to 85% to get it down for posting. They should still be more than adequate.
#12 Keith Almond
  • 5,307 posts
Posted 23 May 2021 - 11:47 AM
Or of course if you need them in a different colour (or a different mortar) Filter Forge can do that too ...
Attached File  Paving Slabs 2.jpg   500KB   0 downloads
Attached File  Paving Slabs 2 - Offset.jpg   508KB   0 downloads
#13 Keith Almond
  • 5,307 posts
Posted 23 May 2021 - 12:04 PM
I think my JPG's are half the size they should be to display the correct size. You may have to adjust the double the display size in Softplan. So the 24" x 24" tiles will probaby display as 12" x 12" and the 30" x 24" tiles will probably display as 15" x 12"
#14 David Edlin
David Edlin
  • 45 posts
Posted 25 May 2021 - 04:53 AM
Hi Keith,
What about this type of flagstone laying, where you have different sizes shapes and colours?
Can this be done within Filter Forge or would one need to create their own filter for this effect?
Many thanks
David Edlin
#15 David Edlin
David Edlin
  • 45 posts
Posted 25 May 2021 - 05:21 AM
Attachment did not take last time
#16 David Edlin
David Edlin
  • 45 posts
Posted 25 May 2021 - 05:24 AM
Hopefully, it is attached.
#17 David Edlin
David Edlin
  • 45 posts
Posted 25 May 2021 - 05:30 AM
Attached File  Marshalls Paving.png   595.39KB   0 downloads
#18 Keith Almond
  • 5,307 posts
Posted 25 May 2021 - 05:59 AM
Offhand, I can't find a filter like that. Although i'm sure that there is something that can give that effect. It's just finding it. The filter creators sometimes are using a similar effect for something different, and  haven't given the keywords that you or I would try to use.
Worst case scenario is that you learn to use the various filter commands and design your own. But I don't find it either simple or intuitive.
I'll keep searching and if I find anything suitable, I'll post it.
You can also search filter forge's filters ... https://www.filterforge.com/filters/ ... if you find anything suitable let me know and I'll tweak colours and sizes for you as necessary.
#19 Heather Baldwin
Heather Baldwin
  • 4 posts
Posted 16 June 2021 - 08:45 AM
In your 3D model, right-click the deck edge and check the skirting box. You have two options for the placement, below the deck edge or in front of it. You can change the height of the skirting to be whatever you need it to be.
