I am using the renovator version, just was told that the material list is very limited compared to the full version of software. The tiles do not appear on the material list. Any suggestions? Crated a wall: Plate A, Studs, Plate A, Plate A, cement board, tiles, the cement board does not appear in the material list either.
Tiles do not appear in the material list
Posted 24 August 2020 - 02:26 PM
I've never used that version. Do you have access to the wall definitions? If so, is SoftList checked in the material line for both the cement board and tile? Is the wall definition you are using a new wall or existing wall? I have my existing walls set so nothing shows in SoftList (not sure if SP would have done that). Do you have the ability to check materials in the wall edit menu (Selections Tab)?
#6
Posted 31 August 2020 - 08:42 AM
Hi Daniela.
Wall tile is typically added as an interior finish rather than as part of the wall definition. The remodel material list is configured to count wall tile that is added as a wall finish in Interior mode.
I'd encourage you to send the drawing to our support department. They can take a look at your drawing and and make recommendations to help you with the output to your material list.
- John Jones likes this
