Joist editing
#1 gary wood
gary wood
  • 98 posts
Posted 30 August 2020 - 09:43 AM
I have drawn a house and am attempting to draw an enclosed porch on the front. I already have interior joists drawn at 9.25" and when I add joist to porch area 4" offset down they are drawn at 9.25".When I edit them to 7.25" the entire floor gets changed to that dimension. How do I just edit porch floor.
#2 Henry Buckner
Henry Buckner
  • 342 posts
Posted 30 August 2020 - 10:54 AM
   If you're using floor system instead of deck to draw the porch floor, edit the porch floor system and set it as "Level 2"
  • John Jones likes this
#3 gary wood
gary wood
  • 98 posts
Posted 30 August 2020 - 11:14 AM
I ended up doing a deck and it worked that way but now I will try the edit floor  thank you
#4 Mark Petri
  • 1,507 posts
Posted 31 August 2020 - 07:34 PM
Use of levels is the only way around such things. Every time you add another floor system part, be sure to check all to see if they moved. Sometimes unknowingly a floor level with default and something you thought was set on one level with change with others.
