Wide bottom rail
#1 JASON BURMEISTER
JASON BURMEISTER
  • 24 posts
Posted 13 October 2020 - 12:18 PM
Is there a way to remove the front toe kick from a base/tall cabinet (wide bottom rail)? I see that there is something to turn left, right & rear toe kicks on and off but I do not see anything for the front toe kick.
#2 Mark Petri
  • 1,874 posts
Posted 13 October 2020 - 01:30 PM
You can change the settings in the System/Project/Drawing Options level under Cabinets / Base. Or, you can use wall cabinets and change the sizes and offsets to match the size of base cabinets you want, then draw a counter separately. Another option is to use back panel and change offsets and sizes. But hardware doesn't show (I think).
  • JASON BURMEISTER likes this
#3 JASON BURMEISTER
JASON BURMEISTER
  • 24 posts
Posted 13 October 2020 - 02:03 PM
Ok Thanks. Will probably go the route of using wall cabinets as it's just a couple of cabinets in an island.
