CENTER LINE
10 replies to this topic
#1 Ron Sirolli
Ron Sirolli
  • 302 posts
Posted 29 November 2020 - 04:59 PM
IS ANY PLACE THAT I CAN FIND A CENTER LINE IN THE SYMBLES FOR THE CENTER OF A DOOR OR A WINDOW
THAT WOULD BE A LINE WITH A C THROUGH IT
THANKS RON
#2 Kevin Rabenaldt
Kevin Rabenaldt
  • 391 posts
  • LocationSan Antonio
Posted 29 November 2020 - 08:33 PM
There is a line pattern that is a centerline pattern.  If you need show that on a window, you can turn snap on and then use a line from the center of the  window.  It would not be attached to the window however.  I don't know of a way to change the extension line to the centerline pattern.  And if there is in system or drawing options, it would change all the extensions or you would forever going back and forth to options.  There is in character map a CL symbol that you copy and paste in a note.
#3 Ron Sirolli
Ron Sirolli
  • 302 posts
Posted 30 November 2020 - 04:15 AM
thanks Kevin i was just worndering if there was one so when i send out the plans it would show the vender
#4 Chris Proost
Chris Proost
  • 142 posts
  • LocationRichmond, VA
Posted 30 November 2020 - 07:39 AM
Ron - Edit the extension line and change it to the old style centerline linetype.
  • John Jones and Ben Ginther like this
#5 Kevin Rabenaldt
Kevin Rabenaldt
  • 391 posts
Posted 30 November 2020 - 07:58 AM
Chris, learn something new everyday.  Thanks.
  • Chris Proost likes this
#6 Tim Stockton
Tim Stockton
  • 343 posts
  • LocationWichita, KS
Posted 14 December 2020 - 09:51 AM
If you need to see the CL symbol that is proper for center line, type Alt 0130 in a note and then move the note over the line itself.
#7 Ron Sirolli
Ron Sirolli
  • 302 posts
Posted 14 December 2020 - 10:06 AM
thanks Chris; not sure what Tim Means
#8 Mark Petri
  • 1,872 posts
Posted 14 December 2020 - 10:42 AM
You can use the CL text symbol (from character mapping) to label the center line if you want. That's what he means.
  • Tim Stockton likes this
#9 Kevin Rabenaldt
Kevin Rabenaldt
  • 391 posts
Posted 14 December 2020 - 10:47 AM
Ron, if you go to character map and look under the font you are using you can find a lot of interesting things there.  There is "CL" symbol that you could cut and paste out of character map into a note edit.  Tim was giving a short cut while in note edit I believe but the exact location of the different symbols in character map have different locations.  I picked a bunch of symbols I thought would be useful and put them into a symbol (or speed note for that matter).  Then I can explode the symbol, cut and paste what I want into my note.  Fractions are helpful because the fraction symbol (many are available in eights) make for a better looking note.
  • Mark Petri likes this
#10 PAUL LADNER
PAUL LADNER
  • 77 posts
Posted 19 December 2020 - 03:33 PM
In SPHAND font the key stroke CTR+0130 will give you a centerline symbol.
Attached File  _KEYBOARD SHRTCUTS.jpg   19.12KB   2 downloads
  • RUSSELL LITTEN and Jon Davis like this
#11 Keith Almond
  • 5,301 posts
Posted 21 December 2020 - 07:49 AM
That should be ALT not CTRL.
  • Jon Davis likes this
