It would be nice if Softplan would give a total of all the area's that are in the model. When you generate an area schedule it would give the individual areas and a total. That being said when you are outlining an area you have an option to include or not include an area in the total.
AREA TOTALS
Posted 03 December 2020 - 06:28 AM
There could be a lot of upgrade to the area calculations. I routine need to supply the areas to the outside of finish material and the areas to the outside of stud. The builders pay based on the latter. Outside of finish material is what the appraisal districts use for the area for property tax calculations. If I could create two different models on the same drawing, then when I need to adjust the design I need to go through the area adjustments for both. I also total areas by groups, first floor and second floor heated areas, porches, garages, etc., and it would great if I could assign which group each belongs to and calculate their totals.
- Stephan Page likes this
Posted 03 December 2020 - 01:11 PM
There is one way, it's not the best but it works...
If you're using plan set's, then putting an area table on any plan set page will result in the table calculating all area's within the plan set.
So what I do, is put my elevations on the first page, along with a table on contents and a total area table, in the upper right corner.
If I have multiple floors, whether they are on one page or multiple pages, it adds them all up in this table. I usually change the name to "total area" or Overall SQFT, something to signify that it's a calculated quantity of all area's.
#9
Posted 17 December 2020 - 03:14 PM
also, it would be nice if the @AREA stamp would show the area live on screen. (not just when you print)
If you're just wanting to keep track of sq. ft. while drawing, you can turn on the Area Labels & Area Values in visible items. Maybe put them on a "NO PRINT" layer or just turn them back off once your design is complete.
#12
Posted 18 December 2020 - 10:51 AM
Not sure how to get rid of “Newbie”. SoftPlan user since vs. 07 in 1994
More posts! That is the only way to not be a newbie I know of.
Back on topic (sort of) - I think all schedules and text options should get major upgrades, but I am glad we have the ability to customize and use tables, text stamps, and layers to control much of how I like my plans to present. I am glad they gave us the ability to add as many areas, finishes, layers, building options, etc. as we want. That alone is so much better.
- Jim Johnson, Keith Almond, Tom Rogers and 2 others like this
