Gable Accent with with radius
gable accent profile
10 replies to this topic
#1 Danial Anderson
Danial Anderson
  • 57 posts
  • LocationMichigan
Posted 10 January 2021 - 05:02 PM
Looking for direction or guidance on how to use a gable accent and the bottom horizontal board to be a radius/Ellipse shaped
picture attached
Thank you
#2 Steve and Carla Farnam
  • 680 posts
Posted 10 January 2021 - 06:43 PM
Daniel you could uncheck the bottom chord of the gable accent in editing.
Add a bottom chord beam with desired vertical curve deflection. Setting shown for bottom
chord in attached file.
  • Keith Almond, Danial Anderson and Allen McDonnell like this
#3 Danial Anderson
Danial Anderson
  • 57 posts
  • LocationMichigan
Posted 11 January 2021 - 07:05 AM
Thank you,
recommendation works.
1) do i need to draw a separate solid piece to make the vertical leg extend below the underside of beam?
2) How do i change the color of this modified beam without making all other beams the same color/texture.
Thank you
#4 Mark Petri
  • 1,871 posts
Posted 11 January 2021 - 09:20 AM
You can change the material you have set for that beam so it is different than all others. And, you can use a post or solid shape to represent the king post extending below the bottom chord.
  • Danial Anderson likes this
#5 Joseph Smith
  • 853 posts
Posted 13 January 2021 - 01:40 PM
Funny you should ask.  10+ years of SoftPlan, my home designs and exterior and interior decorative arched trusses....forgot how many different ones I've actually designed.  whew!  i've started to fabricate them in my shop in my spare time.
I either create them in sketchup or softplan as solids then export them to .dwg then re-import them as symbols in the symbol wizard...works pretty slick!
Joe
  • Mark Petri, Rick Kingsbury, Steve and Carla Farnam and 8 others like this
#6 Mark Petri
  • 1,871 posts
Posted 13 January 2021 - 02:32 PM
Nice work Joseph - I really like your designs and style. Cutting and assembling them in real life is even better. Great to see those types of details actually get built.
Once clients settle on a look I typically draw or modify almost all timber accents in SketchUp. I find it much quicker and more controllable than in SoftPlan. For those who don't use SketchUp it is all possible with solid shapes in SoftPlan. Just gotta think through the assembly and offsets of the different parts.
For me, SketchUp is a great addition to SoftPlan. Cutting different views, sections, parts, and adding hardware is also better with SketchUp.
  • Joseph Smith likes this
#7 Joseph Smith
  • 853 posts
Posted 14 January 2021 - 10:17 AM
Thanks Mark!
Agree Sketchup is a great tool for symbols, when I create in SoftPlan I need to clear the model then use my symbol drawing ONLY in the model in order to create a .dwg of the symbol 3d, this process is a little time consuming but necessary to achieve what's needed.
Looking forward to see what 2022 has instore for us with symbol creation!
  • Mark Petri likes this
#8 Kevin Rabenaldt
Kevin Rabenaldt
  • 391 posts
  • LocationSan Antonio
Posted 14 January 2021 - 11:40 AM
Joseph, interesting to see them designed and built by the same person.  I have not had to do many trusses over the years.  I used Sketchup many years ago but did not keep up with it, time to get back to Sketchup.  What material do you use in your truss construction?  They are nicely done.
#9 Joseph Smith
  • 853 posts
Posted 15 January 2021 - 08:27 AM
Usually 8/4 poplar if primed and painted or western red cedar if not painted.  I used to lag screw and glue with galvanized lag screws and tightbond III then backseal the holes with dowels now i use Kreg HD screws and tightbond III.
  • Rick Kingsbury and Danial Anderson like this
#10 Danial Anderson
Danial Anderson
  • 57 posts
  • LocationMichigan
Posted 20 January 2021 - 08:06 AM
Thanks guys for sharing these conversatiosn. It opens my mind to a keep learning
#11 Keith Almond
  • 5,298 posts
Posted 20 January 2021 - 12:05 PM
Daniel you could uncheck the bottom chord of the gable accent in editing...
Steve,
There is no option to UNCHECK the bottom chord, and in my testing, even changing it to 0 still leaves a line.
Is that what you intended?
