Softplan Drawings to Sketchup
8 replies to this topic
#1 Steve and Carla Farnam
  • 655 posts
Posted 28 January 2021 - 08:37 AM
Good Morning,
  Recent request to export .spd to Sketchup. Will DWG or DXF, after
exporting , import into Sketchup ?
 Steve
#2 Henry Buckner
Henry Buckner
  • 342 posts
Posted 28 January 2021 - 08:49 AM
I think it will.
#3 Mark Petri
  • 1,512 posts
Posted 28 January 2021 - 09:12 AM
If you have SP+ you can directly export the 3D model to SketchUp. Go to the SV window, Then in the main menu on the left you can choose to export via the SoftPlan+ Publish tab and choose "Export SketchUp Model".
#4 Steve and Carla Farnam
  • 655 posts
Posted 28 January 2021 - 09:15 AM
Mark, I am able to export 3D to SketchUp. The request from builder is for exporting the .spd files in .dwg or .dxf. to be then used in sketchup for truss design etc
#5 Mark Petri
  • 1,512 posts
Posted 28 January 2021 - 12:20 PM
Bummer. It is really nice to take slices in every direction with the model. But, DWGs ought to work okay depending on how they import them.
#6 Tim Stockton
Tim Stockton
  • 313 posts
  • LocationWichita, KS
Posted 01 February 2021 - 10:57 AM
Steve and Carla - why not export directly to DWG or DXF from SP?
#7 David Zawadzki
  • 663 posts
Posted 01 February 2021 - 11:17 AM
Doesn't SoftPlan export directly to Mitek?  Would that work for truss design?
#8 Steve and Carla Farnam
  • 655 posts
Posted 01 February 2021 - 12:47 PM
Tim, I have exported o DWG and DXF, the issue comes when trying to import the files into sketchup ( not recognized )
David, The Builder would like to import to Sketchup and then design Timber Frame Trusses and generate shop drawings in Sketchup
#9 Mark Petri
  • 1,512 posts
Posted 01 February 2021 - 01:18 PM
I think exporting the 3D and allowing the timber truss guy to create the views and section cuts he wants in SketchUp is best. But, it all depends on what he is using and how you work the exports. I don't see why a DWG plan, section or elevation from SP isn't importing to SketchUp correctly. You may have to look at your export settings. And, he may want to check his import settings. It does not import the text or line styles, but he ought to be able to refer to a PDF for that information. He could actually import both and place them on top of each other for reference, then turn off visibility of the PDF when not needed.
