Dimension settings
11 replies to this topic
#1 Steve Pirtle
Steve Pirtle
  • 44 posts
Posted 30 January 2021 - 05:56 PM
I have tried for an hour to make my dimensions grab the outside of a board &batten wall . It keeps stops on the interior side and puts the 3 1/2” dimension on the exterior side. Is the something I’m over looking, tried all the different settings to no avail. Thanks Steve
#2 Fred Russell
Fred Russell
  • 607 posts
Posted 30 January 2021 - 06:37 PM
Go to your wall definition, by editing the wall and select definition at bottom left, at dimension and extension for board and batten, open up and select outside on both.
then the way I usually do the dimension, is open dimensions and select "dimension point and click at outside of board & batten, then go to where you want to measure,
This will skip all that 3 1/2" stuff by using "Dimension Point".              There are other ways to adjust the "Wall definition that would work, but this is how I would and  do it.
#3 Steve Pirtle
Steve Pirtle
  • 44 posts
Posted 30 January 2021 - 08:05 PM
Thanks Fred it works great !
#4 Henry Buckner
Henry Buckner
  • 342 posts
Posted 31 January 2021 - 08:10 AM
You can get rid of the wall thickness display in dimension settings (drawing options, project options etc) as well. Uncheck the box that says
"Display wall thickness"
#5 Fred Russell
Fred Russell
  • 607 posts
Posted 31 January 2021 - 08:35 AM
Henry, great, wish I knew that one earlier,   need to do in project and system if you want it on this project and future
what does  "Line Through wall" do
#6 Steve Pirtle
Steve Pirtle
  • 44 posts
Posted 31 January 2021 - 09:39 AM
Thanks Guys they both worked great
#7 Henry Buckner
Henry Buckner
  • 342 posts
Posted 31 January 2021 - 10:34 AM
"Line through wall" doesn't do anything, so far as I can tell.
If you go to the help (user's manual) menu and search for that term you'll be directed to a page that instructs you
on editing dimension settings. There's an illustration that shows dimensions with and without "line through wall" checked.
They look exactly the same to me.
#8 Harald Schwegel
Harald Schwegel
  • 74 posts
Posted 02 February 2021 - 02:59 PM
"Line through Walls" controls the appearance of the dimension line when dimensioning to multiple points on a wall i.e. thickness, it has no effect when dimensioning to only a single point on a wall i.e. inside or outside edge.  The Help illustration is not very clear but the two states are different.
Hope this clears up any confusion.
  • John Jones likes this
#9 Fred Russell
Fred Russell
  • 607 posts
Posted 02 February 2021 - 04:23 PM
thanks
#10 Henry Buckner
Henry Buckner
  • 342 posts
Posted 02 February 2021 - 04:43 PM
Other than the captions below them, I see no difference in the 2 images.
#11 Gary McKeon
  • 553 posts
Posted 02 February 2021 - 09:54 PM
There is an actual line that goes through the wall when the "line through walls" is checked. There isn't when it isn't.
#12 Henry Buckner
Henry Buckner
  • 342 posts
Posted 03 February 2021 - 07:11 AM
Now I see it, thanks.
