I'm in agreement with Keith most of the time.
two main things i consider before breaking a drawing away from the project are:
1. wall definition; any change i may do to tweak a wall on a drawing is unaffected by the other drawings within the project...keep in mind foundation levels where i change up my dimensions slightly.
2. option changes of any kind...i'll have to adjust each level drawing if i break away from the project.
___
** for tech support or anyone in charge please post a video of how to use drawing options template configuration AND drawing option template in system options (keep the video simple for all of us to understand...i'm slow). its showed up in V2020, i've messed with it early on and had poor success so gave up. I see potential but shy away.
Yes ... It's expected behaviour ... As all the drawings are linked in Project Options.
You can turn it off by going to Drawing options and CHECKING Use Custom Drawing Options rather than Project Options. The downside is all the drawings are now independent.
Personally, I prefer Individual drawing options. I would even want my drawings to START with Custom Drawing Options, as the time taken (EVERY TIME) you change something is excessive. I have to go into every drawing and turn Project options OFF.
NOTE TO SOFTPLAN: I would like my drawings to be independent. That's why we have drawing options. That way I can make custom changes to individual drawings without changing the whole project ...
