predictive dimensioning
8 replies to this topic
#1 Chris Robinson
Chris Robinson
  • 72 posts
  • LocationKelowna, B.C. Canada
Posted 24 February 2021 - 12:52 PM
I am a long time Softplan13 user. I am very fluent in floor plan drawing and dimensioning in that version. I have recently upgraded to SP+.
I do not want the program to automatically dimension my plan plans. I just don't like what it dimensions and I want to control this. I have been working on a test drawing. I don't mind the program adding dimensions as I form the plan but when i am ready finalize the construction drawings, I typically erase the dimensions and add extension where I want them then add my dimension. The program keeps adding dimensions over my dimensions and this is getting old. I don't need to tell any of you that dimensioning is the most important part of any drawing. How do I turn off this feature that wants to guess where I want to add a dimension. I hope I have explained this right. I am not using the "auto dimension" command
#2 Henry Buckner
Henry Buckner
  • 342 posts
Posted 24 February 2021 - 12:56 PM
There's a button on the toolbar for "auto dimension". If you toggle it off it will stop.
#3 Bryan Schultz
Bryan Schultz
  • 68 posts
Posted 24 February 2021 - 01:09 PM
Chris - see attached picture.
#4 Chris Robinson
Chris Robinson
  • 72 posts
Posted 24 February 2021 - 03:26 PM
I did do that and still when ever I place my curser on my drawing, ( when I had just dimensioned something) it wants to add a dimension in one direction or the other. Hitting escape should cancel the command but it doesn't. Is this just something I will need to get use to?
#5 Tim Kenyon
Tim Kenyon
  • 20 posts
Posted 24 February 2021 - 04:03 PM
There is also a box you can check or uncheck in the System options named "Display Temporary Dimensions".  Upper right corner.
Posted 24 February 2021 - 07:10 PM
Not that one either ...
The AUTO DIMENSION on the toolbar does just that ... it AUTO DIMENSIONS ... it's not a toggle switch.
In the System Options menu (shown above) uncheck AUTO DIMENSION AND EXTENSION
#7 Chris Robinson
Chris Robinson
  • 72 posts
Posted 24 February 2021 - 09:47 PM
That's it! Perfect. Thanks Tim and Keith.
#8 Henry Buckner
Henry Buckner
  • 342 posts
Posted 25 February 2021 - 09:03 AM
<The AUTO DIMENSION on the toolbar does just that ... it AUTO DIMENSIONS ... it's not a toggle switch.>
That's not quite right. On my toolbar there are 2 auto dimension buttons . The one on the left is the command and the one
on the right toggles auto dimension on and off.
#9 Keith Almond
Posted 25 February 2021 - 04:10 PM
Apologies Henry. I wasn't aware there were two different Auto Dimension toolbar buttons. Thanks for pointing that out.
