Is it possible to have a wall tilting outwards from the base on the vertical axis?
Tilting Walls
Posted 21 January 2015 - 01:01 PM
Maybe,
-You could use profiles added to each side to create a sloping wall.
Or perhaps just use one profile that is a parallelogram.
The question would be if the walls and openings would cleanup correctly.
-Chris
Posted 23 January 2015 - 04:10 PM
showing a raked wall > leaning out.
this was done with "one" profile and it's the only material.
play with doing it with more materials.
you get frame showing with more than one material.
you can get the inside with another material sloping
or
standing plumb (vertical) by not giving the inside material a profile.
when using all wall materials
put the profile on the outside "SIDING" material in the wall definition (at end of wall definition at far right side when editing).
the siding has to be the same "width" and "height" as the definition (VERY Important)
tip: practice editing a wall / edit / left click on "definition" (when the editing window appears
and than "save as" and give it a "new NAME"
this is where you put in your siding "profile" at far right side for the new raked wall or any wall your changing and saving.
v10 to future 2016+
