Has anyone here tried cutting a hole in a ceiling system that has the ceiling grid displayed? I have an area that I drew a ceiling system in and have the grid display turned on, but after drawing a hole in that ceiling the grid still displays through the hole cutout. The shading is removed from the hole, so I know it is being cut in the correct ceiling object, I just cannot seem to figure out how to make the grid lines not show through the hole as well. I have tried using both the "Ceiling Hole Polygon" tool and the "Ceiling and Joist Hole Polygon" tool to see if that makes a difference, but the end result is the same with either one. I'll post a screenshot so you can see what i'm talking about, I would appreciate any help you guys might have.
Hole In Ceiling Grid
Started by
David Johnson
, Mar 03 2021 10:39 AM
No replies to this topic
