Curved Bottom of Beam
8 replies to this topic
#1 Tom McConnell
Tom McConnell
  • 277 posts
Posted 05 March 2021 - 12:12 PM
See Image.
It can be made of solids or whatever in 3D.
Plan view doesn't matter (will hide it).
How can I achieved this beam?
Attached File  Beam.jpg   27.73KB   0 downloads
SoftPlan+ 2021
OS - Windows 10.0 Pro 64 Bit
MB - ASUS ROG Strix X570-E
3Dconnexion CadMouse
#2 Steve Haarmann
Steve Haarmann
  • 645 posts
Posted 05 March 2021 - 12:18 PM
I use a wall instead of a beam.
Set the bottom of the wall at the raised height.
You can then add an arched top opening and control the height and the radius as needed.
  • David Zawadzki and Stephan Page like this
#3 Sam Morgan
  • 851 posts
Posted 05 March 2021 - 12:31 PM
I do it just like Steve mentioned
#4 Mark Petri
  • 1,510 posts
Posted 05 March 2021 - 06:34 PM
Would be nice if not only we could curve a beam like the top of a window or arch (top and bottom of beam deflect). But choose to curve just the top or bottom if we want. I do have beams set up in my wall definitions too. And, if I am concerned about total accuracy I make the parts in SU and import.
#5 Fred Russell
Fred Russell
  • 619 posts
Posted 05 March 2021 - 07:52 PM
I had luck using one straight beam above several or one beam for each arch. looked great in 3D and floor plan and the roof liked it, also elevation enjoyed it, was pretty fast to do,
It's been about a month ago, was good
#6 Jason Bishop
Jason Bishop
  • 295 posts
Posted 05 March 2021 - 10:21 PM
That is (9) separate beams.
Set all with “join tolerance” to zero. Adjust the straight beams the required length. Set the deflection in the ‘arched’ beams as needed.
#7 Richard Rubinski
  • 606 posts
Posted 06 March 2021 - 07:36 AM
I used a 2' high Stucco Wall, offset it up and unchecked cleanup. I used a Camber Arch uncased added exterior trim, then I added Banding at the top and bottom of the 2' wall.
  • Michael Landry, Jim Johnson and David Zawadzki like this
#8 Richard Rubinski
  • 606 posts
Posted 06 March 2021 - 10:38 AM
This was my first attempt a couple of years ago.
https://softplantuts...ront-Porch-Beam
#9 Richard Rubinski
  • 606 posts
Posted 06 March 2021 - 11:30 AM
Here's a Brick Arch on a Porch. I added a Product Code to this Arch so that all I have to do is adjust the width when I use it again.
  • Stephan Page likes this
