Measure curved property line to curved building line
#1
Posted 17 March 2021 - 01:09 AM
Posted 17 March 2021 - 08:24 AM
There could a number of reasons. Try turning off arc chord visibility by editing the individual arcs, there is an option there, and then dimension. If that does not work, draw a line from one arc to the other arc where you want to dimension, then pull a dimension extension from each end of the line and dimension the line. You can also use offset under tools and offset the distance you want and then position the house (group and use group move if you moving the whole set of house lines and need to keep them together).
- Jonathan Verduzco likes this
#7
Posted 05 April 2021 - 07:04 PM
