Insulation slope with ceiling
#1 Danial Anderson
Danial Anderson
  • 57 posts
  • LocationMichigan
Posted 03 April 2021 - 05:29 PM
I have my roof, rafters and ceiling drawn and at a x/12 pitch
I add ceiling insulation and i do not see a way to give it a slope like the ceiling.
I know that i can draw a box with the insulation symbol, just seeing if i am forgetting something
Suggestions Welcomed
Thank you
Dan
Posted 03 April 2021 - 07:51 PM
I'm not at a Softplan computer, but I believe that If you edit the ceiling you can add the insulation to it directly in the ceiling menu.
  • Sean Tobin likes this
Posted 03 April 2021 - 07:53 PM
Alternately, if you're just drawing it in section, adjust the curor angle to match the roof pitch, and draw a box or a line with insulation texture to suit.
#4 Katia Cline
Katia Cline
  • 20 posts
Posted 09 April 2022 - 11:19 AM
Hi Keith,
Any idea how I can get the insulation texture to appear as an option when I edit the polygon I drew on my sloped ceiling?
Thanks!
  • Larry Hartensteiner likes this
Posted 09 April 2022 - 12:11 PM
Draw an angled line through the centre of it and edit the line to have a thickness and change it's texture to insulation.
Alternately, put the polygon on a separate layer. Turn off the visiblility of other layers. Make a paint pattern by exploding a insulalion line and creating a custom paint, and paint the polygon with it.
You could also trace the polygon with a shade break and add a custom shade paint.
I have so many insulation paints, but I can't remember if any of them are standard - I don't think they are, but creating a custom paint is simple. For insulation I'd recommend having multiple custom depth paints to suit the insulation thickness that you are going to use.
#6 Katia Cline
Katia Cline
  • 20 posts
Posted 09 April 2022 - 02:51 PM
Thank you! I never noticed the option to select different textures for lines before. Very handy!
