I was wondering the different ways folks are creating 3D chimneys for their elevations/renderings. With all the different material (brick with row locks, siding with trim, etc) and variety of shapes and tops it has been a bit of a sore spot for me. Short of building with blocks, planes and so on or finding a Sketch-up drawing online somewhere that sort of works what other ways are there? Thanks.
3D chimneys
Posted 19 April 2021 - 11:15 AM
I normally add another floor plan called Chimney Plan and use standard wall construction with a custom built 3D symbol as a cap - of course it's never shown on plans ... purely for the model.
- Warren Ducote and Allen McDonnell like this
Posted 19 April 2021 - 04:15 PM
I often do something along the lines of what Keith does. It allows all the flexibility of walls and trim to be used. I do use a solid or several for caps, etc. when representing and not worried about detail.
- Allen McDonnell likes this
#5
Posted 04 May 2021 - 10:27 AM
I use walls & solids to create the 3D and just put them on a layer that doesn't print on the plan. I would love more options on the Spark Arrestors! I've had to make my own in Sketchup, but the material selections for wire-mesh doesn't exist in either software. I would literally have to make it in Sketchup and I'm not going to do that for a small item, so I fake it with other materials.
- Todd Williard and Isaiah Baker like this
Heather Baldwin, AIBD, CPBD
heather@baldwinlakedesigns.com
(801) 652-3117 Cell
#6
Posted 04 May 2021 - 11:03 AM
Heather, Go to https://www.sketchuptextureclub.com/and create an account. There are a ton of free textures there. You can download a perforated metal texture and apply it to a solid. Remember that in order for transparency to work it has to be a png file. This is a SoftPlan Cylinder with a black perforated metal plate texture.
- Mark Petri, Rick Kingsbury and JEREMY MILLER like this
#7
Posted 04 May 2021 - 11:49 AM
And here's a seamless chain link texture that may work for you.
Chain Link.png 495.19KB 4 downloads
Don't forget to check transparent in the surface editor.
- JEREMY MILLER likes this
Posted 04 May 2021 - 03:18 PM
Here's some Chicken Wire if that works better for what you want.
Although to be fair, I've no idea what a spark arrestor is, where it goes, or what it looks like ...
Chicken Wire.png 802.27KB 1 downloads
Posted 04 May 2021 - 03:39 PM
Posted 04 May 2021 - 03:42 PM
Although putting complex Seamless textures on Softplan's cylinders doesn't work too well, as the cylinder is made of a number of straight sides, and the textures add to each side independently and it breaks the "Seamless" part of the seamless texture.
If you create a symbol or even a part of your drawing with a PLANE, you can add many different effect by using planes and transparent textures for fencing etc.
May 4, 2021_18h22m59s_002_.png 933.12KB 3 downloads
- Jim Johnson and JEREMY MILLER like this
