SP20 i was able to dimension directly to cabinets. In SP22 it is going to the ctop. How do i change it back?
Cabinet dimensions.
#5
Posted 23 April 2021 - 02:10 PM
Cabinet
#7 Guest_Derrik Bauer_*
Posted 25 April 2021 - 09:30 AM
Cabinets here too. Trim carpenters need to know where to place the cabinets. The countertops installers don't care where the cabinets are, just that their top is sitting on them.
I do use the extensions on the countertops to show bar overhangs though.
- Allen McDonnell and David Zawadzki like this
#8
Posted 26 April 2021 - 07:13 AM
I agree with Mark. Typically the cabinet body is the point of dimensioning, however there are times where clearances need to be shown from countertop edges. I find this to be more common when working on commercial buildings where ADA regulations must be taken into account when designing a layout.
#11
Posted 29 April 2021 - 03:20 PM
I do not understand the issue. I can dimension cabinet to cabinet or countertop to countertop using Dimension Point.
correct....do not want to have to use dimension pt. with "symbol" highlighted you should be able to dimension cab to cab. Thats how it was in SP20 and should have remained.
- Keith Almond likes this
#14
Posted 14 May 2021 - 02:03 PM
#15
Posted 14 May 2021 - 03:16 PM
Users requested the ability to dimension to countertops. The dimension command places a dimension between the nearest dimensionable items which now is the countertop. Dimension point places a dimension between two dimensionable points, skipping over other dimensionable items.This is the command that you would use to dimension to a cabinet box while passing through the counter top. It is unlikely that SoftPlan would remove the ability to dimension to countertops given that you can dimension to cabinets using an existing command. Providing an option or preference is a larger change because it would require a change to both the user interface and to the configuration file format. CO 53709
That's very disappointing. Big miss.
#16
Posted 14 May 2021 - 03:37 PM
Yes, agreed.
I always dimension to cabinets. Only when there is something tight or large overhangs on countertops do I dimension them, and dimension point is more than adequate for that.
The question is did more than 50% of users ask for it, or was it just a few people that asked if it was possible. just because some people asked, doesn't make it a preference for everybody, and that's what you seem to be implying!
- Jim Johnson and John Jones like this
Posted 14 May 2021 - 08:05 PM
#18
Posted 14 May 2021 - 08:11 PM
In 2020 you can put an extension on a countertop and dimension it that way.
- Jim Johnson and Allen McDonnell like this
