Lines disappear when moving?
Block move
16 replies to this topic
#1 Clint Hiebert
Clint Hiebert
  • 16 posts
Posted 27 April 2021 - 07:11 AM
Has anyone experienced this? If I press ctrl and highlight the areas I wish to move as a block, the minute I click or press home to start moving the highlighted block everything disappears until I click or press home again. The block moves, I'm just totally blind until I click again and it reappears. Unless I type in a dimension to move there's really no way to tell where it's going to land and I just hope it's in the right place.
#2 Chris Proost
Chris Proost
  • 139 posts
  • LocationRichmond, VA
Posted 27 April 2021 - 08:38 AM
Yes, I have had this happen intermittingly.
#3 S. Sin
S. Sin
  • 23 posts
Posted 27 April 2021 - 11:16 AM
I see it happening on multi drawings.  Dont think ive experienced it on a single drawing file yet.
#4 Joseph Smith
Joseph Smith
  • 824 posts
  • LocationWI
Posted 29 April 2021 - 09:08 AM
Yes it happens with ctrl picking.  Text ctrl picking drops text NOT where its supposed to go most of the time also....which is more annoying.
2022.2.7 update may have corrected this issue...difficult to determine.
Joseph A. Smith
http://granitedesigngroup.com
#5 Clint Hiebert
Clint Hiebert
  • 16 posts
Posted 03 May 2021 - 06:55 PM
No this was not corrected in the update unfortunately. Can replicate on every drawing.
  • 5,098 posts
Posted 03 May 2021 - 07:20 PM
Apparently, the 2022.2.8 update was released today. Try that!
#7 Clint Hiebert
Clint Hiebert
  • 16 posts
Posted 04 May 2021 - 05:36 AM
Problem persists after the 2022.2.8 update. Again, just in a multi-drawing environment.
#8 JEREMY MILLER
JEREMY MILLER
  • 25 posts
  • LocationColumbus, OH
Posted 04 May 2021 - 10:15 AM
I have experienced the same problems and some items that I am not moving disappear and do not reappear with a general cleanup.  I often have to close that drawing, sometimes the whole project and reopen it to clear the display error. I've reported it to SP Help and they've sent it on to the development team. I would suggest the same as the more who do, the more likely it is to be corrected in the software.
Heather Baldwin, AIBD, CPBD
heather@baldwinlakedesigns.com
(801) 652-3117 Cell
#9 John Pepper
John Pepper
  • Administrators
  • 406 posts
Posted 04 May 2021 - 02:20 PM
Thank you for the information. The fix for this particular issue will be in the next patch. CO 53783.
#10 Joseph Smith
Joseph Smith
  • 824 posts
  • LocationWI
Posted 18 May 2021 - 07:43 PM
if we're talking about the same thing, this is still a a problem.  CTRL-picking then moving or copying the insertion point jumps around.  Sometimes it works and other times it does not.  I created a ticket on this already.  i have the issue mostly with copying shapes or text....the insertion point is not accurate when placing the copied item.
Is anyone else continuing to see this?  i've created another ticket #67918 just now.  thanks
Joseph A. Smith
#11 Chris Proost
Chris Proost
  • 139 posts
Posted 19 May 2021 - 06:43 AM
Yes, this is happening to me too
#12 John Jones
John Jones
  • Administrators
  • 251 posts
Posted 19 May 2021 - 06:48 AM
Chris,
Can you please create a support ticket so we can take a look.
#13 Joseph Smith
Joseph Smith
  • 824 posts
  • LocationWI
Posted 19 May 2021 - 09:54 AM
Ticket Number: 67918
Chris,
Joseph A. Smith
#14 John Jones
John Jones
  • Administrators
  • 251 posts
Posted 19 May 2021 - 09:59 AM
Joseph,
Thanks we received your ticket, we're looking for a project from Chris so we can see if it's the same behavior.
#15 Chris Proost
Chris Proost
  • 139 posts
Posted 19 May 2021 - 10:56 AM
John - See my support ticket #67950 to replicate this.
  • John Jones likes this
#16 John Pepper
John Pepper
  • Administrators
  • 406 posts
Posted 19 May 2021 - 12:34 PM
Joseph,
We were able to recreate your issue using the drawings associated with ticket 67918. CO 53906.  This only seems to happen when you are using Visible Items->Display Print Pen Style.
Unchecking that option should fix your issue in the interim.
Attached File  display_print_pen_style.png   27.88KB   2 downloads
  • John Jones and Joseph Smith like this
#17 Joseph Smith
Joseph Smith
  • 824 posts
  • LocationWI
Posted 20 May 2021 - 01:11 PM
wow, i never would have figured that.  ok thank you!
Joseph A. Smith
Also tagged with one or more of these keywords: Block move
